D
danwendling
How can I tell what kind of fuel pump I have on my 2009 C6?
I want to add a supercharger and need to know if I can add a voltage based boost a pump.
My 09 Shop Manuals imply that all the pumps are controlled by the FPCM (Fuel Pump Control Module) and use PWM to control the pump pressure. I dont think I can use a voltage booster for the PWM pump.
I have heard that this applies only to the ZR1, so hence the question.
Also is the Z06 pump different than the C6? Heard that it depends on the VIN as both were installed in 09 depending on part availability.
