pwr steering control valve and cylinder
  • Thread starter Thread starter grpups
G
grpups
I'll be replacing my pwr steering control valve and cylinder and would appreciate any and all hints, tips, etc. thanks.......
The power steering cylinder piston attaches to the frame bracket. Look very carefully at this bracket and the frame section it mounts to for cracks. If there is a weakness in this area, the increased pressure from the new valve and cylinder may cause it to break right off.
It happened to me--one day I something felt funny in the steering, so when I got to my driveway I cycled the steering wheel lock to lock a few times. There was a loud snap followed by a metallic clunk. I got out of the car and saw the frame bracket and half the power steering cylinder lying free on the ground along with a small section of frame. The frame section has no rust; this was simply a metal fatigue issue. It would not have been a good thing for this to have happened while cornering.
If my '77 had this weak spot, I'd say it's well worth checking on yours.
I have an article in the April issue of "Corvette Enthusiast" magazine (will be out in about two weeks) on changing the power steering control valve; has lots of detail and photos, would probably be helpful to you. :)
John Hinckley
Vintage Technical Editor
"Corvette Enthusiast" Magazine
thanks for the replies.....will keep all in mind.......
thanks Rare81......excellent and helpful information......now i just have to wait for my parts to arrive.
Rare 81 and JohnZ: Thank you for the information and advice. I also am waiting on my new power steering component parts to arrive.--G.P.Black
Yes, it is - the April issue of "Corvette Enthusiast" hit the newsstands and mailboxes last week. :)
John: I bought the April 2005 issue of Corvette Enthusiast. today. Excellent article! Very detailed! I have the replacement parts, just need the time to do the work.
Question: Can (or should I) use Teflon Tape on the hose fittings? I understand that the fittings should not leak if torqued correctly, but I have seen them do so. Any thoughts or comments? Will the tape "hurt" anything?
Note: I never knew that the zerk fitting on the bottom of the control valve should not be greased! Thanks for that tip!
No need for Teflon tape on the fittings - the seal is at the flare surface, not the threads. :)
Question: Is it a common problem for the valve to not hold adjustment?! It keeps pulling to the right...I correct the valve very slightly, and it's good for a day or so, and then starts pulling again.
The valve is relatively new in miles, but a couple of years old now.
Thanks!
- Jeremy
Answer:
Nope! Once you set that balance adjustment on the cylinder, that should be that. The problem is probably with the control valve. A bad O-ring in the valve is my bet.
If my '77 had this weak spot, I'd say it's well worth checking on yours.[/QUOTE]this also can be caused by running oversized tires.....I hav e used the system for a 1958 thru 1964 full size chevy and found it worked nicely.....
just a hint
Mike
Very valid point - I noted that specific issue in my article; if the retainer plate studs and nuts loosen up that hold the bracket to the frame, it "rocks" under lateral load from the power cylinder, which places a point stress on the frame as the bracket pivots on edge, which can then fatigue and literally "tear" that portion of the frame out. Happened to a friend's '74 big-block a couple of months ago; not a fun experience, and costly to repair.
