seems like as long as you are willing to use unleaded race fuel and do some serious tuning, more power is available.
I think going to a modern aftermarket computer and larger injectors would help the fuel distribution instead of relying on the injectors in the "horn" for added fuel.
on my turbo buick (just for example), I run 18 psi on the street with no detonation, and over 24 at the track. some of the crazees run up to 28-30 on the leaded 116.
I'm currently running 72 lb injectors with still very good street manners through a corvette MAF.
when you see the big number that the turbo supra guys post, a radical callaway would be cool. but keep in mind the "production" contraints on the b2k and warrenty and you see why they kept the HP to reasonable levels.
once you start to modify the car, you really need to beef up the rods and bottom end and tune for zero detonation or you will quickly become aquainted with blown HG, hammered bearing, broken crank and pistons. I went through a couple turbo v6 motors and alot of knots on the head before I finally learned.
good news is that the v6 stock stuff used to be dirt cheap. not anymore.
trips to reeves to replace stuff isn't as affordable.
JT, why not just TT the ZR1 and have the best of both worlds!!!
interested???
