'67 coupe.
The AIM says 7 clips across the top of the windshield. OK
The AIM says 2 corner retainers. OK
The AIM says 16 clips down the sides and across the bottom. Not OK.
I screwed all 23 of the clips in and had two holes left over - bottom middle - like in the photo.
Should there be two this close together on both "sides"?
If not, I'll have two for the center-bottom. If I remove one, which one? And, why is the hole there if not for a clip? It's the same on both sides.
Thanks.
![assembly10-350.jpg](http://www.computersupport.ca/Restoration/assembly10-350.jpg)
![assembly09-350.jpg](http://www.computersupport.ca/Restoration/assembly09-350.jpg)
Thanks.
