Question on drilling in center cargo area
hot4u
Celtenham, MD.
2008 Artic White Coupe
What's behind the fiberglass in the center cargo area in the coupe and is it safe to drill to brackets to add a aftermarket CD changer.
When I installed a CD changer in my rear compartment area, I drilled through the bulkhead and installed a grommet for the wires:
Here's what's in there now:
Measure twice, drill once. ;)
Hot4u , are you refering to the storage area under the floor with the lid ? Or are you talking about out in the center of the whole area . The center cubby hole in the back is the factory location for a changer . You can drill into the vertical bulkhead in the back .It's thin and you may want to use a drill stop but I didn't . Cliff
If you're talking about the rear bulkhead in the very rear, I think it's the steel cross member between the frame rails. It will stop the drill unless you decide to continue drilling into it. It's tough, so to make a hole in it, you would have to be very deliberate about drilling. So if you're wondering if you will hurt anything, I think you will be OK.
When I installed my GM Cd changer, I mounted it per the instructions, which is the same as the factory installation.
vettepilot
vettepilot
That's what I'm talking about I'll gice it a try It's just two self tapping screws. thanks for all the replies
I think the only thing that's under there is the fuel tank. So you'll be fine.....
Just kidding, I don't know what's under there..but i bet the gas tank or transmission is close by...so be careful.
-Dave C. 04 Z06
