since I have the top of my '65 L76 motor open including the valve covers off, I was studying the motor to learn more about how it works and how things go together.
I noticed that on my rockers that some of them are very tight and have no movement side-to side if you push against them but others are very loose and kinda wiggle easily if you push against them.
I had the valves checked and adjusted back in the summer by the JohnZ cold method so was wondering if this looseness on some of the rockers is normal or not.
At first I was thinking that maybe the differences were that because some were intake and some are exhaust valve rockers therefore the adjustments would be different, but there is no pattern on which ones are loose and which ones are tight.
Any insight would be appreciated.
Thanks!
Thanks!
