I just got my Holley 2818-1 rebuilt and as i've been trying to get the timing and carb adjustments made I noticed a few things i'm questioning
1. the butterfly valve(?) on the very top that I thought normally opens and closes over the primaries is in full verticle position and it will not move at all whether the car is cold or fully warmed up to operating temp or if it's idling or revving. Shouldn't it move at times? I thought it did previously. Even trying to move it manually it doesn't budge at all like it's locked into place somehow
2. I can watch as I pull on the accelerator level as the primaries will open looking down into the carb, but the secondaries are not opening at all. is this normal without the car actually being driven? I would have thought that they would open as I revved her high enough.
3. even after the rebuild I don't think the choke is operating properly as it won't stay running unless I keep tapping the gas to keep the idle up until she is warmed up than she idles just fine.
are the choke and that top butterfly valve related to each other that could be working together to cause some of these problems?
I hope I'm using the right terms so you understand what I'm trying to describe and ask
