vin # 194676s125640 block @rear 3782870 block front of right head 5111634 fo219ht thanxCan you post the engine numbers? There should be two stamped on the pad at the front of the passenger side head. One should be all or a part of your vin. The other is the engine build number with letter codes. It would be easier to tell you what you have than to list them all here.
VIN digits are as follows: (Sample number: 194676S100001)
"1" indicates Chevrolet Motor Division
"9" indicates Corvette
"4" indicates V8
"67" or "37" indicates convertible or coupe
The sixth digit (6) is the last digit of the model year
"S" stands for St Louis Assembly
followed by a six digit buile sequence number.
Tom
