MartyCee
We are in the process of trying to install headers on a 72 roadster and realized that we will need to find an adaptor in order to mount the existing AC compressor.
At this time the AC does not work. There are several issues involved with getting the AC working and we have too many other fixes going on at this time to attempt to repair it. Therefore we would like to remove the AC unit temporarily and reinstall it when we are prepared to deal with it. Can we remove and shelve it until we have the time to repair it properly?
Also, just out of curiosity, can anyone shed any light on a couple things that involve the AC wiring? We found two or three loose wires with melted connectors, two that look as if they go into some type of plastic (somewhat melted as well..) sensor. Also there is a sensor/sending unit mounted on the block (right rear) that has two spade terminals but nothing is connected to it. (Possibly a couple of the loose wires we have lying near by?) At this time the AC is not a concern and it would be nice to have the compressor (especially) out of the way so we aren’t too worried about these wires. However when we are ready it would be nice to have some insight as to where these wires connect. Are there any potential problems with disconnecting the compressor and shelving it until we are ready to tackle any necessary repair?
Also how difficult would it be to upgrade the R12 system. And if when we do upgrade, can we replace the long compressor with a shorter one?
Any advice or insights would be appreciated.
Thanks - Marty
Thanks - Marty
