I checked with Costco and was told a set of run-flat tires would cost around $1300, and regular tires around $800. Part of my quest for a sports car is to determine how expensive it would be to maintain. Tires seem to be a significant cost. I was surprised to see insurance would be around $700 per year which seems reasonable for a vehicle with this performance potential.
How many miles can you expect from regular non run-flat tires. I would most likely be driving fairly conservative most of the time.
The person at Costco stated he wouldn't recommend using regular tires; Questioning what I would do if I had a flat.
So what do you do if you have a flat while using non run-flat tires. He also stated you wouldn't be able to plug the tire, because you couldn't get the tool through the tough carcass.
I'm also considering a Honda S2000. It would certainly be cheaper to maintain with cheaper to purchase tires. I'm 6'1" and the cockpit of the Honda is tight.
This group will be biased for the Corvette, but I'm still interested in any comments as to which car I'd be happier with.
Phil
