Looks like many of you folks use your cars as daily drivers so you probably have discovered the problem I'm about to describe. I've noticed when opening the rear hatch on my 02 Coupe in the rain, most of the collected rainwater on the back glass and painted area just behind will empty itself into the drainage trays so quickly that a lot of the water will run over into the back speakers. The car is waxed often so the rainwater collects and beads up, adding to the amount of water. I've tried opening the hatch slowly and it helps, but I still get some water over the speakers. Any ideas (short of not driving it in the rain) to keep the interior dry? BTW, the seals around the hatch appear to be in good shape.
Like the way you're thinking GMJunkie. I was looking at the Folgers big size. It's already red (color keyed) and it says it's good for 90 more cups!!!! It says so right on the can.
) I've got a Idee!! STAND BY!!
