In researching articles I've written on the development of the GTO, I had access to quite a bit of test data from Pontiac Engineering. Pontiac offered "Ram Air" systems for several years on the top-end engine options, but test data showed, as John states above, that the hood scoop has to be located a minimum of 6" above the hood in order to get out of the "boundary layer effect" and produce actual "Ram Effect" above 90 mph. For styling reasons, marketing nixed any scoop that tall, resulting in open "Ram Air" hood scoops that had no ram effect whatsoever - the "Ram Air" systems on GM cars, including the Vette, were marketing gimmicks with limited, if any, actual performance gain. They did allow the engine to draw in cool outside air that had not been heated up in the engine compartment, but there was no ram effect at all: The forward-facing scoops simply don't have any ram effect unless they are located significantly above the surface of the hood, and you're moving at a high rate of speed.
If you're going to spend a ton of time and effort to create a "ram air system," you're better off spending that time and money on other areas, unless you simply want to create an illusion of ram air, as GM marketing was doing.
Lars
