LannyL81
- Joined
- Jul 20, 2002
- Messages
- 653
- Location
- Oro Valley, AZ USA
- Corvette
- 81 White/Cinnabar, 96 CE LT4 sil/blk
After several set-backs in getting my '81 back on the road again...I have reached yet another one. I have fought and battled against dropping the trans (again), but have run out of options and things to try.
The hard shifting problem continues and reverse just grinds and grinds. I have the clutch rod adjusted to the end and even with the cluch pressed to the floorboard...grinds and grinds.
I know the flywheel was resurfaced, but do not know how much was taken off. How critical is this? Do I need to get a shim between the crankshaft and flywheel? New flywheel? Or is it just this RAM PowerGrip clutch? I am hoping that may be the throw-out bearing came off one side of the clutch arm and that is what is causing all my problems....but still requires all the work involved in dropping the trans (again).
Anything else I could try before doing this?
I just want to drive my 81 instead of work on it. It's been two years now.
Lanny
Tucson, AZ
Lanny
Tucson, AZ
