J
jmp
Hey there... I pulled out my dist to change the tach cross gear (72 LT-1, btw) and I'm now ready to put the dist back in. Problem is, it doesn't seem to want to go back in! The dist won't go all the way back in to the engine -- it sits about 1/2 inch up.
Is there some trick to re-installing the dist? Nothing got moved while the dist was out -- crank's still in the same place, and I marked the dist body/engine and the #1 spark plug location on the dist itself.
Thanks!
Thanks!
