Real time damping
  • Thread starter Thread starter jari
J
jari
In Finland we have a shock absorber test.:mad Every shock tests at time, test time about 20sec. I have 1997 Corvette/ F45 suspension and test shows “bad shocks”. Service manual hasn´t any descriptions what I can use to explain that shocks don´t work when car is steady state. Where I can find some descriptions how does the RTD works, so I can show to them that they can´t test the shocks without driving the car?;help
Thanks Jari
Hi there,
The following is the information from GM as to how to test your shocks.
These shocks are NOT like the newer magnetic F55 shocks, so you may use this.
Personally, the control module for the F45 will set a code if the speed of the suspension overrides the shock and its not working effectively.
Stroke shocks by hand at various rates of speed. Stroke selective ride shocks at different rates of resistance by manually rotating the selector gear on the top of the shock.
Observe the resistance.
Rebound offers more resistance than compression (approximately 2 to 1). The resistance should be smooth and constant.
Compare with a known good shock.
A hissing noise is normal.
The following are considered abnormal and reason for replacement:
- A skip or a lag at reversal near mid-stroke.
- A seize (except at either extreme end of travel).
- A noise such as a grunt or a squeal after completing one full stroke in both directions.
- A fluid leak
- A clicking noise at fast reversal.
Allthebest, c4c5
