Any tips on how to drain and refill the rear axle in a 1986. I figure I can use one of those hand pump brake bleeder setups to suck out the old lube, but I'm looking for a shortcut to refill the axle. Also what is the correct ratio of lube to anti-slip additive? I thought it was one bottle of additive to one 23 oz bottle of GM lube. Not sure and don't know where to verify it. I know someone on this forum has the answer and may be willing to share.
This is what they wanted me to use for the gear breakin period. It did have some fine metal grit in it that I was told to expect. So one more drain/refill should get the rest out. If you're small you can get in there without jacking up the car and do the whole job. You do want it level when you fill it.
