Rear Coil overs for 91 ZRI
  • Thread starter Thread starter Hoddsac
H
Hoddsac
Hi,
Looking at replacing my rear Top Flight Corvette coil over suspension system with something which has a better mountings top and bottom (The eye type of coil over shocks look the best). The current set up on the top end in particular is very poor and the shock rod continously punches out the rubber bushes and then proceeds to chew away at the rod itself. What is the best rear kit to use as a replacement ?
Regards, Alan Hodds
QA1 make a conversion kit that converts a shock with 9/16"-18 piston rod thread from stud mount to loop ( eye) mount utilizing 5/8”or 1/2” bolts.
