L48
On my 75 where the rear control arm comes out of the frame, it appears to be much closer to the inside of the frame rail than the outside of the frame rail. The outer end of the halfshafts actually appear to be tilted slightly toward the front of the car as well.
I am wondering if the control arms are bent.
There are no obvious hammer marks but the car came with really wide rear rims and I wonder if there was a clearance problem that someone "fixed" by bending the control arms.
The halfshafts are hitting the axle stubs and I think the geometry is messed up because of bent control arms. Maybe the bushings are bad? Since I only have one Vette I can't really check to see if how the control arm comes out of the frame. If someone knows or has a pic of what this should look like I sure would appreciate it. Thanks.
