dk1977
First .. sorry for the long post, but I'm almost at meltdown...
I have seen past posts about rear end noise but I'm still looking for advise. I have a '77, L48, auto. The car has 145k miles. Differential looks to be original.
After the car is driven a few miles, (warmed up) about 50% of the time I hear a grinding / grating noise from the rear end, mainly when making a left hand turn. You can feel it , like something is really rubbing. Also, when under power and you lift from the gas, the car wants to pull to the right for a second or two.
Heres what I've done so far..
New rear bearings: .002 end play measured "on the car"
Replaced the front differential mount, 2 OEM style pads and bolt.
New spring, mount plate and end grommets.
New u-joints on half shafte and driveshaft
I jacked the car up and there is considerable "play" if you move the tire while holding it at 3 and 9 o'clock. All bolts and mounts seem tight and no signs of anything rubbing. Pulled the half shafts and I measured the end play of the stub axles (in differential) @ .050". The trailing arms seem tight at the bushings.
Is the stub axle play excessive and could this be causing my problems?
If so, any recommendations for a fix? I've searched the internet and found FastCorvette.com that list some complete differentials (with stub axles and shipping) for around $1200 (no core). Anyone dealt with these folks?
Any thoughts will be appreciated.
