vsg914
I'm replacing a rear hub assy on the 96. The book says its a torx head. Can anyone tell me what size torx? I've tried, but there is no way I can see in there.
Thanks in advance.
Curt
Thanks in advance.
Curt
No lube.....its a sealed bearing.....Thanks- This helps me as well.
While I'm unbolting it, forgive me if I mutter "Why couldn't they just use a hex (allen) bolt. I already had a set of hex key sockets.
Do you need to grease the bearing or is it "permanently lubricated?"
Thanks!
Thanks. That was it. I got it changed yesterday. about 3 hours total. Old bearing fell to pieces in my hand when it was removed from the spindle.
