J
JOE BYRNE
I thought I would share a story with all of you newer guys who were thinking of replacing your rear spring. I Worked on my 73 over the winter and put a new distributor and carb on along with new mufflers. I thought I was done with everything until my rear spring broke last Saturday as I was pulling into a parking lot.
I came home Sunday and soaked the bolts for the center plate and end links. My first bit of bad luck was not letting the bolts soak long enough. Yep three came out and the ear broke off on the last one. I talked to my mechanic and he said he could weld the ear on. He told me to put it on with three bolts and run a fouth threaded bolt on and run a nut down just incase the spring moved.
Feeling a bit better I ordered the spring Monday morning and asked a friend to help out Saturday. Wedneday the spring was at the house and being a dummy I decided to at least get the center bolted up. I fought with it and decided to jack the spring up on each end. It worked and seemed to be perfect until I looked at the one end that was just a hair off. I attemped to pry it a bit and in the process the spring snapped down and hit me in the temple.
Im not sure how much time went by (I think only a few minutes) but when I came to I was in serious pain. Thank god I was not bleeding but just very swollen.
Moral of the story.....when putting a steel 30+ pound spring in have someone help!!!!!!!!!!!!!!!!!!!!!!!!! or have someone do it for you. I did finish it up tonight as my wife was...well you know.....
