vettebuff
On my '86 the rear left side is about 1" lower than the right side. On front it is about 1/2" lower on left side. It can be leveled by adjusting the screws at the rear springs, but need 2-3" different setting left-to-right. The rear spring has been taken down and turned and all links have been disconnected and greased, front and rear. No visible damage to front spring or other suspension parts. Still not level. Can this be a frame issue?
Background: after owing the car for 20 years I spin off the road and slid sideways (left side) on the roadside, plowing both front and rear left wheels in the dirt and finally hit the 6ft high shoulder with bumper at front left side. The front "bumper" and the frontmost frame cross member was damaged and replaced. The shop said that the front portion of the frame at the point where the bumper is attached also was bent but not more that they could mount the new bumper with some adjustment shims. (However, I doubt that that shop has the right knowledge, so I have my suspicions). The doors close and open exactly as before, and with same gaps.
To me it was not that of a hard crash so I have difficult to see the frame being affected as far back as the point of the front suspension. Now I am living on last piece of hope, what can I check next, can there be anything else than the frame that is causing this non level ride height? The car was level before the incident. Or how to check the frame?
Thanks, Per-Hakan
Thanks, Per-Hakan
