Les55
My right side sensor is in the left pipe, left is in the right. Is that normal?
My right rear sensor isn't setting. I put short tube headers on my LS1. Check engine light comes on. Diagnosis is low pressure right bank. Right rear sensor not setting.
I bought the after market adapter to fix the problem, but I don't know if it goes in the left pipe where the right sensor is, or the right exhaust pipe, where the left sensor is.
Can some one help by telling is this is normal, and which side to put the adapter.
Thank you
Sent from my SM-N960U using Tapatalk
Thank you
