D
Doug'sL81
Hi again,
Thanks Rare for the posts on chambered mufflers. This weekend I was removing the drive shaft, not a big deal, thanks to you all. While I was at it I wanted to replace the rear tranny seal. Well, it seems that Vettes are kind of unique in that everything is a PITA even simple things like removing the rear seal. Access to the seal was difficult in that the cross member was in the way so I pretty much had to tear up the seal trying to get it out. I also tried to remove the tail cone to make it easier, after putting my aging body trough some impossible contortions I was able to get at the four bolts holding it. However, that damn cross member was in the way again I couldn’t remove the tailpiece all the way. Has anyone removed the tail cone without removing the cross member? Also the U-joints for the drive shaft I bought at NAPA were too large, their book says the same U-joints all around for automatic and smaller driveshaft U-joints with manual. It could be wrong in their book cause the smaller U-joints did fit. All in all I had a great time getting greasy, now if only my neck would move.
