Well,
Finally found the time to replace the rear spring on my '81.
I discovered the original composite spring had cracks and de-lamination about a week after I bought the car, so I did a little research and ended up buying a 330lb composite spring with urethane bushings from VBP.
Talked to a few folks and did some read-up on the swap before I started. A friend who has a couple of early 70's C3s had me a bit nervous with his tales of floor jacks being thrown through walls by springs!
In any case, the whole swap only took about an two hours, including putting the car up on the jack-stands. (Yes, I put the heat shield back on)
Not a difficult job, but probably not for a greenhorn.
The bad:
It would have been nice to have an extra pair of hands once or twice, and the instruction sheet from VBP really could use a picture or two.
The good:
Ahh...it sure is nice to feel the rear of the car turn into a corner at the same time as the front! What a difference a new spring made over the original, tired old GM spring (still had the GM parts label on it!) The ride is smoother and at the same time, stiffer in corners. Definately increases my cornering confidence.
Suggestions:
Make sure you have two floor jacks; I found it a lot easier to align the trailing arm bolt holes, spring bolt holes and all of the bolts, washers and bushings with a jack under the trailing arm as well as the spring.
Air tools were invaluable...there were a couple of bolts that were just a bit stubborn!
Make sure your friends have returned all of the wrenchs they borrowed before you start. I sure could have used a 13/16" wrench....
Can't wait to see what a front end rebuild and a set of swaybars will do!
Dave
Sorry, I know I should have taken pictures...couldn't locate my camera.
The bad:
The good:
Suggestions:
Dave
