Rear Strut Installation
ed_in_pa
Langhorne, PA
1976 White Coupe
Hi all,
I'm sure this is addressed in a previous quote but with this sites migration to new servers the search function doesn't seem to be working. In a long list of while I'm doing this I should do this. I started by removing my fuel tank to fix a leak. Then the metal fuel tank cover came out to wire brush and paint, then I started wire brushing the frame in the rear so I can POR 15 it and then I decided to remove the leaf spring bolts & bushings and replace them. Since I'm doing that I might as well replace the struts. Does anyone have any tips or advice about replacing the struts? I know there is something about marking the camber bolt. Any other tips on the leaf spring or painting would be appreciated.
Thanks,
Ed
Thanks for the info Bob, you don't by chance have the second part (front end) for future reference.
