Welcome
Berry, Welcome to CACC. I hope you find this a great source of information and community.
It is interesting you note this problem. The truth is, it may simply be the spring, and or it could be a dozen other things.
1. The quarter panels may have been bonded unequal from the factory.
2. The body mounts could be worn/collapsed or loose.
3. Rust in the frame.
4. Prior frame damage
5. Bad spring/spring mounts collapsed.
Guldstrand is a community vendor here and could provide you with the products and support you need to get it straight.
I am also running the complete VB&P suspension. I have not driven the car either, so can't say what I really think of it yet. Redmist here has the full blown suspension on his car and has been driving it. He may be able to give a little more feedback.
One quick easy solution can be to simply adjust the bolt/nut on the rear spring mount. You can shim inbetween to raise it, and losen the nut to lower it.
You might also try jacking the car up on level ground in the front only. Plut the front of the car on jack stands set at equal height under the frame rail (not on the lower control arms). If the car still sags, it will help you narrow it down. Sometimes a tweaked front suspension can make the rear sit different as well.
Good luck, let us know what you discover.
