Rear tire has a wiggle....
H
hdcwagsvette
I noticed that my rear tire seemed to be leaning inward on the top (toe in) When I jacked up the car it turns out the rear wheel could be moved top to bottom and left to right. Tried to tighten the lug nuts more but that was not the problem. Do you think the rear axle bearing needs to be replaced or is there something more to it? ;shrug No more wiggle...replaced the bearing, thanks a lot guys.
So Cal
1996 LT4 Collector Edition
The top to bottom wiggle is wheel bearings. Side to side might still be bearings, but might also be toe rod bushings.
Victory Red C6
Gibbon, MN
2007 Victory Red Coupe
Sorry to say, but your rear wheel is not toe in due to the problem. What you have is a negative camber angle, due the problem.
Toe:
Toe is a measurement of how much the front and/or rear wheels are turned in or out from a straight-ahead position. When the wheels are turned in, toe is positive (+). When the wheels are turned out, toe is negative (-). The actual amount of toe is normally only a fraction of a degree. The purpose of toe is to ensure that the wheels roll parallel. Toe also serves to offset the small deflections of the wheel support system that occur when the vehicle is rolling forward. In other words, with the vehicle standing still and the wheels set with toe-in, the wheels tend to roll parallel on the road when the vehicle is moving. Improper toe adjustment will cause premature tire wear and cause steering instability.
Camber:
Camber is the tilting of the wheels from the vertical when viewed from the front of the vehicle. When the wheels tilt outward at the top, the camber is positive (+). When the wheel tilts inward at the top, the camber is negative (-). The amount of tilt is measured in degrees from the vertical. Camber settings influence the directional control and the tire wear.
Too much positive camber will result in premature wear on the outside of the tire and cause excessive wear on the suspension parts.
Too much negative camber will result in premature wear on the inside of the tire and cause excessive wear on the suspension parts.
Unequal side-to-side camber of 1° or more will cause the vehicle to pull or lead to the side with the most positive camber.
A good start would be to check the wheel bearings. Good luck with getting your problem corrected.
gmjunkie
Old Fort NC/Vero Beach FL
03 Z-51,78 L82 Coupe
You need a wheel baring!!! And Soon!!!!!:upthumbs
H
hdcwagsvette
Toe:
Camber:
Alrighty then....thanks for the lesson.
S
speedmaster4
anything to do with a bar, i'm in :D...you should change that rear bearing assy so the car won't weave on the way and cause a leo to grab you for dui...unless your last name is ''hilton'', then don't bother.
H
hdcwagsvette
Replaced the rear bearing and all is well. Thanks guys
