Help! Rear View Mirror Day night function quit working
mdebry
New member
california
2004 coupe
The electrochromic mirror has quit working, no green power light. All other lights work, reading lights, vanity mirror lights, hood light all work which also come off the 2 fuses, so power is avail. Any one know of some fairly easy trouble shooting before I relent to a repair shop. I have a 2004 C5 coupe
Not trying to be antagonistic or sarcastic, but did you try the power button on the mirror (see p. 2-38 of your Owner's Manual)? It's possible you or another driver just inadvertently turned it off...? :confused
Yes I did check the switch, however problem is solved. Turned out to be the fuse located in the inside fuse box. I had read that 2 fuses supply power to mirror, and that they also power underhood light, vanity mirrors, reading lights and a few other items. Since everything else worked I assumed it was not a fuse.
