Question: Rear Wheel Bearing
John Robinson
Gone but not forgotten
Muncie, Indiana
1993 Polo Green Coupe
I had the car into my tire dealer today because over the weekend on the Interstate I had a vibration that was speed sensitive. 70 MPH was all I could cumfortable go.
After spinning the tires we discovered that one of the front tires has a slight bulge in it.
When I picked up the car the guy at the desk said that the tire balancer told him I had play in the right rear bearing.
I jacked the car up and used a dial indicator to measure the flex in and out for both rear tires. My readings showed that they were flexing about 7 to 8 thousands as best I could tell. Can anyone tell me what the acceptable movement is.:confused:v
I don't know exactly where your checking the movement John,but if it is at the tire or the edge of the rim,7-8 thousandths would be very little movement at the bearing it's self!!!:thumb
Hey Junk the left seal on my 2004 rear end was leaking,found service bulletin,had the work done,is there a break in peroid(before wot)???Someone said 300 miles before I can go to wot, but I cannot remember who said it.Thanks in advance hope to see you in October at TotD.:beer
