C
Cream79L82
Well it turns out I was wrong again with what I thought my problem was. As soon as I took the dust cap off of the bearing assembly and saw grease that was still blue I knew they were fine. The noise that I was hearing was from my brake pads rubbing on the rotor under no pressure. I replaced four seals and boots.
Of course, I still have a number of questions... is it necessary to bleed the whole brake system if just the fronts were opened? How freely should the wheel spin when jacked up under no pressure? Is it normal for the pads to engage the rotors when the brakes are not applied due to the piston spring pressing out or should the seals keep the pistons back and clear of the rotor when rolling down the road?? And finally, how much play should there be on the rear wheels with the rear end jacked up when you push in on the top/ pull the bottom, etc?? There is alot of noise when spinning the rear wheels in neutral, but I don't know enough to discern whether its drivetrain noise or farther out. There is a fair amount of play when pulling in and out on the tire, so I don't know whether to worry or not....
Thanks.
-Jon
Thanks.
-Jon
