I actually took the Vette out for a short drive today to run it at normal operating temps. Definitely needs chip work, still leaking oil from under the valve covers, may still have a small vac leak, but it's got power even at part throttle... much improved over before.
However... get home, pop the hood to see how things look. Except for the oil leaks, all looks good until I check the oil. There's definitely gas in it, judging by smell, but I don't know how much.
Given that the car just had a fuel injector leak, and I was playing with the injectors (plus the car is running rich and off-time), could I have just introduced enough gas into one or more cylinders while working on that last leak to taint the oil a bit? Also, would this possibly be caused by the new rings not having fully seated yet?
Without pulling things off again (GAH!) is there any way to make sure I didn't wash the oil off one cylinder before starting the car? I realize that any damage that could be done probably was done already...
Thanks...
[RICHR]
Thanks...
[RICHR]
