I did mine a couple of weeks ago. With the console removed, I used a heat gun on the underside to loosen the adhesive. I then lifted the shift pattern and the shift surround with a razor blade and a scrap of thin sheet metal. Be careful when you buy the repair kit if you're going for an original look. I got mine from Corvette America and the numbers on the shift pattern looked nothing like the originals. In addition the brushed finish wasn't even close. I ended up salvaging my original shift pattern and refinishing the new surround to make it look correct. What a bunch of unnecessary work.
ad Good luck!
Jeff
