eants
I may have bit off more then I should have but during the winter months, I decided to rebuild my Q-jet. But what the hey, what else do I have to do in the middle of winter?
After 28 years of use, the carb has a good amount of carbon and other gunk in it. I used high quality carb cleaner and tried not to clean the parts that the manual said not to. I was very meticulous with the dissemble and reassemble. Made sure not to turn any unnecessary screws.
Now that it is starting to warm up I went out and fired her up. She runs well until the choke opens up completely. She will start to kick a little then just dies. She will start back up but she will not idle.
Any recommendations of where to start? Idle screw, mixture, timing, yada, yada.
:confused
:confused
