Y
yellow91
I just had my automatic tranny rebuilt about 4000 miles ago, anyways when I start out in drive or overdrive going about 20-25 then push gas until it down shift, it clunks or grinds (slight slipping) when it down shift (not that bad but noticable) its like a bad u-joint but you think the mechanic would have told me, it doesn't happen when I WOT it but gently push gas until it downshift, is this normal or should I take it back. I can't recall noticing it when I got it back after rebuild. Also if I start out in overdrive and it gets to 43 mph it shift then it shift again at 46-47 mph, not sure if it is torque lock up or shifting into gears. Both of these things happen at a light foot not at WOT. When manual shifting or WOT it is fine.
I also changed the Speed sensor, because it would shift in and out at 40-43 (that solve that problem. When I got my car back, the mechanic told me this was the problem and I knew I could do that myself.
