Are you talking about a C5 issue or C6 issue? You've posted your question in the C6 Forum but you list your Corvette as a "00 convertible".Has anyone had this recall completed? Is it necessary if the steering column is seldom moved? Is it a job that could cause other problems if not done correctly? Thank you.
Jane AnnWould you explain in detail what is the problem for the recall and what is the suggested fix.
Roger
This car is an 06 C6.Are you talking about a C5 issue or C6 issue? You've posted your question in the C6 Forum but you list your Corvette as a "00 convertible".
A quick look at the Corvette Action Center Knowledgebase shows articles listed by 'category' namely generations although there are a few other 'general' headings.
We need more info in order to help you.
Jane Ann
Jane Ann
