hey Lauren,
hawaii and florida probably have similar wheather.high humidity!you probably get plenty attention,female in vette in florida nights will the top off,good for you.anyway,the drain is hard to get to,the smaller your arm the better.i get mine all scratched up.it is on the passengers side,behind the head,coming out of the fire-wall.its very small and has a sharp 90* angle down.i take mine off and reem out the hole with a paper clip.squeeze the hose side a bunch to smash up the scale or silica,what ever that crap is.if you can get the hose out and blow it out,even better.
if the drain backs up,you will notice your passenger floor board soaking wet.if you didnt know,the computer is at the foot board under the carpet.some people jack up the car and go from under neith.my car is so low it takes forever to jack up,so i go from the top,you will need a flashlight,and a little patience.every summer the posts start up about wet passenger floor.some get it worse.good luck,
                           later,Todd.
