remote mirror is out
  • Thread starter Thread starter V..rroom
V
V..rroom
my passenger side remote mirror doesn't work..it was like that when I purchased Y-Vette....the drivers side works ok, but not the passengers...is this just the selector switch that needs replacing or is there a drive motor to the mirror that might be bad??thanks.
Hi there,
The best thing to do is to remove the switch on the center console and check your change over rocker switch.
See if it is working, instead of opening up the door panel.
Allthebest, c4c5:hb
I agree with checking the switch...however isn't the motors for the mirrors behind the glass itself?...I don't think you need to remove the door panels unless you intend to take the mirror housing off. My side mirrors pull out towards the back of the car...they are attached with 3 plastic ribbed dowels. Be careful the plastic can get brittle and break.
c4c5specialist I just noticed you are from Shelton...
:w neighbor
