grumpyvette
just some info, see these, at least in theory a twin remote mount oil filter with an oil cooler can increase the oil capacity , maintain the oil temp at lower levels, and reduce the resistance to flow the oil system sees by doubling the filter surface area, with the added benefit that the filters can be mounted in a more accessable location.
well a fairly comon way to kill an engine is to INCORRECTLY install one of these remote filter adapter kits,
look at the top picture and keep in mind that those two connecting hoses COULD be flipped as to what end(in/out ) on the remote filters gets hooked to the bypass adapter (IN/OUT) ports, hook it up correctly and everything works just fine! but swap the two hoses on only one end and YOUR OIL PUMP tries to push OIL PAST the ANTI-DRAINBACK VALVES on the oil filters,(and most of the time is marginally successfull in that a trickle of oil does get to the bearings and rocker arms at idle) now at idle youll still get good oil pressure (about 15 lbs) but rev the engine and the highly restricted oil flow pressure goes up very slowly but the oil VOLUUM getting into the block is so low youll spin a bearing in about the first 20 minutes ( and 99% of the time the guy that does this blames the guy who built his engine for putting it togeather WRONG when in fact the engine could have been PERFECT but with no oil reaching the bearings under load the engine is history within at best about an hours running time!
