Hi there,
Thank you to the membership for your support. However, Mike simply wants fact, and in that, I can respect his position.
So, lets get started. This information listed is from a 2004 Corvette service information.
First, the description of Power Moding. Document ID 1211546
Normal vehicle class 2 communications and module operations will not begin until the system power mode has been identified. Discrete wires from the ignition switch contacts are monitored by the power mode master (PMM) module in order to determine the correct power mode. The PMM communicates the system power mode to all class 2 modules on the class 2 serial data line.
So, if you are using a system to duplicate the ignition switch in Corvette, then you would have to essentially override the correct ignition switch to obtain correct power moding and every single circuit would have to live. Then, you would override the Passkey to make the fuel enable circuit give the correct password to start the vehicle.
This could set a code B2723, which is covered below, Document ID 680097
The body control module (BCM) supplies a 5 volt signal and a ground circuit for the PASS-Key® system. This allows the BCM to detect PASS-Key® resistance values. Inserting the PASS-Key® (with resistor pellet) in the ignition lock cylinder completes the PASS-Key® circuit. Contacts in the ignition lock cylinder mate with the pellet contacts. The BCM compares the resistance value of the key pellet to the valid resistance programmed into the BCM. If the proper resistance value is read, the BCM allows the following functions to occur: If, for some reason, a constant signal is seen by the BCM, this code will set.
Ok, so lets just say that both of these are successfully overriden. Your next problem would be having all the computers communicate and receive the state of health message. This is covered in data link communications, document ID 1211569.
This vehicle is equipped with a computer system capable of performing multiple engine and body control functions. Vehicle components such as windows, locks, mirrors, etc. are controlled directly by their system control module. Each system control module communicates with other system control modules on a serial data circuit. The vehicle system control modules are all attached to the serial data circuit that provides the data link communications. This data link, or serial data circuit, provides 2-way communication between various engine and body control system control modules.
The control modules connected to the class 2 serial data circuit are listed below:
- Powertrain Control Module (PCM)
- Electronic Brake Control Module (EBCM)
- Electronic Suspension Control (ESC) Module *
- Body Control Module (BCM)
- Instrument Panel Cluster (IPC)
- Radio
- Sensing and Diagnostic Module (SDM)
- HVAC Control Assembly (HVAC) (with CJ2) *
- Driver Door Module (DDM)
- Passenger Door Module (PDM)
- Seat Control Module (SCM) *
- Remote Control Door Lock Receiver (RCDLR) *
* If equipped.
Some electrical system components are directly connected to and controlled by their system control module. Others systems accomplish the control functions by sharing data information with other system control modules on the serial data circuit to execute various vehicle functions. All system data information from sensors, switches, etc. can be monitored by any system module that is connected to the serial data circuit. Communications between each system control module is accomplished by sending a digitally coded message consisting of specific information. Communicating data information with other system control modules on the same serial data circuit, either input information or specific program information, provides more accurate and reliable computer system control functions.
All system control modules on the same serial data circuit use a communication process similar to a telephone system, where enormous amounts of information can be exchanged on a single data wire. The serial data circuit is used to communicate information between each system control module. Each system control module is assigned a specific recognition code, called a source ID. This code is used to identify which module is communicating on the serial data circuit. When a message is sent out on the serial data circuit , the recognition code will identify which particular module sent the message. These messages contain specific information, or commands, a system control module requires to function properly.
When a system receives a message it also "learns" the source ID of the system that sent it. This source ID is used to determine which system control module actually sent the message for State of Health (SOH) monitoring. SOH monitoring determines if a system control module is unable to communicate properly. Description and diagnosis of each system and control module is covered in the respective service manual section.
In conclusion, you can also reference TSB or technical service bulletin, 02-06-05-004a for further information on alarms and aftermarket devices which are causing other problems.
General Motors Engineering, in an effort to determine the root cause of catalytic converter damage, has determined that aftermarket alarm systems incorrectly installed in vehicles have the potential to cause misfire codes and damage to the converter. These alarm systems use a circuit interrupt which utilizes the ignition circuit on the vehicles.
These alarm systems utilize mechanical relays and normal vehicle movement can trigger these relays to engage and disengage the ignition circuit while the vehicle is in motion. These disruptions of the ignition circuit, which occur in milliseconds, may cause more fuel to be commanded. Over time, this dumping of fuel on and off again can cause misfire codes and ultimately damage the converter assembly.
Important
Engineering could not identify any alarms that utilize solid state circuitry that would eliminate this concern. Because of this, it has been determined that all alarm systems must be routed through the starter circuit in order to avoid this condition.
Dealers must be aware of this issue and take note of the wiring on vehicles with alarm systems that come in for repair, particularly for catalytic converter damage that seem to have no known root cause.
So, with all of this that has to be considered, it doesnt even take into the account of the column lock issue that has been plaguing c5. Because the column lock actuator is controlled by the BCM and the ignition key signal. That said, it is too complicated to effectively falsify all signals needed, based on the factual information given above.
Allthebest, c4c5
