cwerve74
I am replacing the front control arm busings on my 74. I have everything off the control arms. The upper control arm will not clear the engine block as I slide it off the bolts. The question is " are the bolts that go thru the control arm welded to the frame?" Should I be able to slide the bolt thru the frame to give me enough clearence to pull out the control arm? Suggestion?
