cwerve74
OK before I tear somting up. I am replacing the front control arm bushings. Have removed everthing from the lower control arm. The bolt that goes thru the control arm in the rear of the control arm (side with just one bolt) attachment to the frame. Is this bolt threaded into the control arm or how is it attached? I am having trouble sliding the control arm off the bolt. I have the two in the front off and the nut is off on the rear. I am starting to get to a point where I am applying a lot of force, so I think I need some help.
Had a similar question for the upper CR but with good help from the forum I have that taken care of now I need to remove the lower.
