Removeable roof panel on 99 C5's
  • Thread starter Thread starter Gary Civiletti
G
Gary Civiletti
I'm having lots of problems with the roof panel on my 99 rattleing, it's getting worse all the time, do others have this problem?
Gary Welcome to the Corvette Action Center Community ;)
I moved this into our C5 section, there are lot's of great folks here and I'm sure you'll have someone along here shortly to help you with your question.
Take a few minutes and enjoy the entire CAC experience ;) there is much more to us than just our Forums ;)
Welcome aboard, Enjoy the :Steer
You can tighten it up (fine adjustment) by turning the rear latch. For a coarser adjustment, you can move the 2 front latching surfaces. The procedure is in the shop manual.
I looked up your problem in my '99 shop manual which describes the following adjustments:
Adjust rear striker to ensure locator pins are fully seated.
Coarse ajustment - loosen rear striker bolts and move striker forward.
Fine Adjustment - loosen set screw and turn hook 1 turn at a time.
Front Striker
Coarse adjustment - loosen striker mounting bolts and reposition up or down
Fine adjustment - loosen striker outboard bolt, slightly loosen inboard bolt and pivot striker bracket up or down on inboard bolt.
Good luck!
I have adjusted my front fittings as described vet4uva above. Only takes a few minutes....
Good luck
