captras
I have a 75 vette that is all original. I would like to replace the exhaust system and get true duals, eliminating the cat. Also I have read about removing, or disconnecting, or blocking the smog pump. If I remove the pump, or just remove the belt, are there any engine/carb adjustments that must be made, or can I just drive it that way. Is there an oxygen sensor that must be removed? Lastly, will this actually make any difference on the performance end.
Thanks in advance!
Thanks in advance!
