Replace the plastic flexible extension cable snaps
Joe8915
Denver
1990 Blue Steel
Can you just rebuild the antenna? I can hear the motor so all I want to do is replace the plastic flexible extension cable snaps.
My 87 was easy. Getting it out is the most trouble. It comes out throught the wheel well. Do some searches you might find some pics. Here are some numbers off the package when I fixed mine.
Antenna Repair Cable for Corvette
22038195
GR. 9.647
Cable
9804E7
on bar code:
0 36666 45350 8
Eckler's number
29285
The housing is riveted you drill them out and replace them with bolts.
Some of the latter antenna you don't even have to take it out to fix it.
JS
22038195
GR. 9.647
Cable
9804E7
on bar code:
0 36666 45350 8
Eckler's number
29285
JS
Antenna, completed and done. On to more fun things to do. Thanks for all the tips.
Thanks for following up and letting us know that the problem is solved.
Andy :w
