96corvetteLT4
Those that have replaced their heater core, did you have problems with fitment of the replacement core?
I removed mine and went to get a replacement at OReiley, it was not the same. The outlet hoses were the wrong length, the top mount notch was off, etc. After checking several other stores, I finally went to get an AC Delco replacement (twice as much money). The first one I got was identical to the one I had. It was made by Harrison (stamped on the bottom tank), but was beat up from shipping. All the rest of the AC Delco replacements have been the same style/fit as the one from OReiley. I have been unable to find another one made by Harrison. I have checked into having my original one repaired, but did not like the repairman's comments - "I will have to grind the tanks off, then replace the core section".
With that said, has anyone else had similar problems?
'96 LT4
'96 LT4
