Replacement overdrive, need advice
The OD I'm installing was just rebuilt by SK. I agree Brian is great to work with. But its time to take the old one out and install the new one and am looking for the expeience I don't yet have. Searched the threads but didn't fond specifics. I'll try again but if someone has a shortcut or link I'd appreciate it.
I'm pretty sure I can get the geast out OK but am concerned about rejoining the OD to the tranny correctly.
If you remove the dist only, it allows you to angle the engine/ trans down enough so reaching the top bellhousing bolts over the trans is easy
