Yes.. we finally got the hatch WS installed
Yes we did it,, but what a job it turned out to be!
ad
The Replacement WS was not at all like the factory one and we too, could stick a fingernail under the glass and see it on the inside of the hatch....so we asked an expert and he informed us that we should take the hatch hinges off and shim them up with U shaped metal and
sure enough it worked. It brought the hatch tight to
the weatherstripping on the top.
The lower part of the hatch where it closes with the two pins, a little adjustment has to be made there, by filing the latch enclosures, and an adustment of the pins, by turning them each a quarter turn and then closing the hatch, we had to do that about 4 times...finally we were able to barely able to to slip a piece of paper between the glass and the WS, which was the final test, before drowning the car in water! :L:L:L
Then we let the car sit out in the hot sun with everything closed and. After many hours of fussing and cussing, we took her out for a test run, for wind whistle, and she has never been so quiet, thought we were in the wrong car!
Now we just have to get used to closing the door with a little more push, and the T Tops require a little more pressure to lock into place, but I guess that is to be expected as the old WS was pretty much sun damaged.
It looks good and when we had to take the car into our Vette Specialist, he said that he could not have done a
better job, so that made us feel really good.
Would we do it again ourselves, after knowing what it
entailed, I think not, but now after installing it ourselves, it would be a breeze...no pun intended.
Thanks for asking about our little endeavour!
Vette Gal
