Replacing a battery in a 2008 C6
JeffW
Arizona
Bought in Feb and believe it had a new battery. Went to start this morning after sitting since Sat and got the dreadded click click click. Anything I need to look for in this electrical playground? Also any tricks that need to be done to replace the battery or do I just pop a new one in?
Thanks, Jeff
If you bought the car in Feb and it had a new battery in it, you shouldn't need a new battery.
If you do, the battery is defective and should be warantied.
I'd charge the battery, then have it load tested. If it tests ok..maybe you left something on or maybe the electrical system has a short or a draw somewhere.
