74 454
I'm about to replace a broken fan shroud and I've heard that you can not get the shroud installed at the bottom without cutting the bottom section in half. This would be down the center line of the car so you can squeeze the bottom together a little cross car. Is this the solution with the vehicle all together, except the fan and clutch assembly of course?
